07 800x2 Lost my keys
Old Feb 19, 2008 | 02:58 PM
2blue's Avatar
Default 07 800x2 Lost my keys
I lost both my keys and need new ones.
Is it hard to get them replaced or does the machine have to be hauled into the shop? $100 an hour labor rate for new keys is a rip off.
Old Feb 19, 2008 | 03:18 PM
snootdog's Avatar
You will have to order a new ignition switch from dealer. It comes with two keys. It is easy to install even with limited mechanical inclination. Should be less than $100.
Old Feb 19, 2008 | 03:19 PM
scootergptx's Avatar
Supersock
Hired Gun!
A completely new switch would be around 70 dollars, and come with 2 keys. Not that hard to put one in.
Old Feb 19, 2008 | 03:26 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
man blue you are havig bad luck it seems. i think you can order new keys via giving the ser.# though a dealer but its probably as almost as expensive. you didnt happen to right down the key number in the manual for keeps sake did ya? just a thought.
Old Feb 19, 2008 | 03:46 PM
Supersock
Hired Gun!
Looking at Ronnies.com, the blank key is $7.15.
But they also say it can be cut from the existing key. If you don't have the code for your old key, the new ignition switch was $63.05.
Old Feb 19, 2008 | 04:25 PM
2blue's Avatar
Where do i find the serial number of the keys?
Old Feb 19, 2008 | 04:31 PM
Supersock
Hired Gun!
When you bought it, there should have been a metal tab like thing along with the keys. That should have had the key code on it.
Old Feb 19, 2008 | 04:44 PM
2blue's Avatar
And then they can make a key from that code rather then replacing the ign?
Old Feb 19, 2008 | 04:49 PM
Supersock
Hired Gun!
That's my understanding of it. I don't have first hand experience doing that, so I can't say for sure. I have replaced a broken ignition before, and if you have to go that route, it's not very hard at all.
Old Feb 19, 2008 | 08:42 PM
trailbound's Avatar
When the dealership set it up they may have written the key number in your owners manual. Check in the book because there is a place for them to write it down. If you can find it there the set-up sheet has is a place for it to be written down there also. Your dealership might still have the paper work. I sitll don't know if you can order it with that number, I couldn't do it with my Yamaha motocycle.
