Exhaust leak?!?!?!?!?!?
Old Feb 20, 2008 | 08:58 PM
nickatnite's Avatar
Default Exhaust leak?!?!?!?!?!?
i just put a HSP can on and i guess in the installation i moved the pipe around. the leak is where the head pipe connects to the main pipe, this is on a sportsman 500. i can move the pipe and it stops. but slowly comes back. i dont know what else to do. another question, when i pin the gas there is a little bog down and then i really gets on it. what can i do fix that?
thanks
Old Feb 20, 2008 | 10:16 PM
nickatnite's Avatar
come on no one is going to answer???
Old Feb 20, 2008 | 10:57 PM
sprinter10's Avatar
i don't know about eh eghauset but teh bog is prob in the carb take it off clean it all out take the bolw off and just go threw it with contact cleaner. then chech teh air micture screw and count how many time it takes to screw it all of the way in. it should be around 2 and 5/8 tures out. thats were i put my scrambler 500 withe the sportsman 500 engine and carb at i also run the K&N air filter i have stock jetting and eghuast thow. I hate that you cant ajust hte mixture screw while the carb is on teh bike that stinks.
Old Feb 20, 2008 | 11:54 PM
matt1969's Avatar
there is a exhaust gasket ring that goes in where its leaking.i just replaced mine about a week ago.17 bucks from Polaris.
Old Feb 21, 2008 | 11:37 AM
nickatnite's Avatar
how hard id it to replace the gasket. any sugg. on how to take the springs off w/o wrecking them
Old Feb 21, 2008 | 11:52 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its the springs that just hook over the loops on the rear exhaust, just take a needlenose pair of vise grips to pull themahead enough to slip off. watch it as they have alot of tenion on them. i actually took a big reg. screwdriver and ground a slot into the end to make a spring tool which you buy.
Old Feb 21, 2008 | 01:23 PM
matt1969's Avatar
its pretty easy.i just used vise grips.there not that tight.
Old Feb 21, 2008 | 09:14 PM
nickatnite's Avatar
thanks guys got it done i ordered a gasket but i was messing with the placement of the pipe and it stopped. so ill replace the gasket anyway when it comes.
Bonzhonda300ex
Sep 17, 2015 10:44 AM
bvolks
Sep 13, 2015 12:57 PM
Sep 10, 2015 01:56 AM
Bigtwin700
Sep 9, 2015 09:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
