4-stoke's most popular oil change
Old Jan 15, 2001 | 01:49 PM
EXtreme-'s Avatar
Before being suckered into Polaris' brand oil for the wifes trailboss, I wanted to see what most of you are running in a popular aftermarket oil? Also, is there a common filter out there or is the Polaris filter a must-buy?
Old Jan 15, 2001 | 02:45 PM
MagnumMudMan's Avatar
Steve
As for the oil, the Polaris oil is a synthetic 0W40. I have not yet found a synthetic oil in this weight, or i would switch. If you want to run 5W30, 10W30, or 10W40, I would run a good synthetic such as Mobil 1 or Amsoil.
As for the oil filter, there are several out there that will fit. If you are not against Fram, you can get a #6607A. Also, if you have an Autozone in the area, you can get Duetch(sp) and use a D371. If you run a search on oil filters, several guys have posted several different numbers, these are the ones I could remember.
Old Jan 15, 2001 | 04:29 PM
girthyguy's Avatar
Polaris uses synthetic oil straight out of the crate? I always thought that you werent suppose to tell everything seats in. Thats really wierd. I heard synthetic cause problems in seating the rings. Oh well i guess you learn something new everyday
matty
Old Jan 15, 2001 | 06:04 PM
scr500's Avatar
All new (since 1998) Corvettes come from the factory with Mobil 1 synthetic,however Royal Purple recommends 1500 mile break-in before running their oil.You can't go wrong using the oil the factory recommends.
Old Jan 15, 2001 | 07:55 PM
Rammer's Avatar
I used a Fram 6607 and the 7317(same as the 6607, but longer) and 5W-30 Mobil-1 in the Sportsman I use to have.
Old Jan 15, 2001 | 09:38 PM
countryguy's Avatar
John Deere makes a 0w40 synthetic but if I remember right it isn't a heck of alot cheaper than the Polaris oil.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
