4-stoke's most popular oil change
Steve
As for the oil, the Polaris oil is a synthetic 0W40. I have not yet found a synthetic oil in this weight, or i would switch. If you want to run 5W30, 10W30, or 10W40, I would run a good synthetic such as Mobil 1 or Amsoil.
As for the oil filter, there are several out there that will fit. If you are not against Fram, you can get a #6607A. Also, if you have an Autozone in the area, you can get Duetch(sp) and use a D371. If you run a search on oil filters, several guys have posted several different numbers, these are the ones I could remember.
