800 header pipe
the 600,700 and 800 use the same block. The 800 header has 2 pipes going most of the way back where as the 600/700 header pipe Y's about 4 inches from the block. There is a slight power increase from using it.
Will the 800 header bolt right in to my '07 700 EFI? Will it connect to the existing exhaust pipe? Or do I need to buy more 800 exhaust parts to make it work? Also, does use of the 800 header on my '07 700 EFI require me to have my computer altered, such as fuel/air ratio, etc. ??
You will have to get the Header pipe, which will bolt right up to your motor. You will have to remove your "Y" pipe that is on there now. You will also need the heat sheild kit. Polaris sells this as a kit and has everything you need to bolt it on.
Header pipe- 1261445-029
(3)Heat shields-
5244014
5248703
5248702
Header to cylinder gasket- 5811511
Header pipe to muffler seal- 3610047
(3)Heat shields-
5244014
5248703
5248702
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
