800 header pipe
Old Feb 21, 2008 | 12:13 AM
polarisman600's Avatar
Default 800 header pipe
does anyone know where i could get a 800 header pipe, to put on my 04' 600?
Old Feb 21, 2008 | 01:51 AM
KING4X4's Avatar
i ordered mine at the dealer but have seen them on ebay i hope this helps
Old Feb 21, 2008 | 07:12 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
maybe check in a salvage yard if you want used.
Old Feb 23, 2008 | 08:49 PM
Indslpwr04's Avatar
I might be wrong but arn't the 600 and 700's Vtwin motor and a 800 is a parrellel twin? Wouldn't that make the head pipe different?
Old Feb 24, 2008 | 09:05 AM
jodaanja's Avatar
My '07 700EFI Is an inline twin, just like the 800. I've never seen a 600, but I'd bet the farm on the fact that it is also an inline twin.
Old Feb 24, 2008 | 09:08 AM
jodaanja's Avatar
I need some education.....Why would you want to put an 800 header on your 600? Wouldn't it make sense to put a 600 header on your 600?
Old Feb 24, 2008 | 10:56 AM
heller1's Avatar
the 600,700 and 800 use the same block. The 800 header has 2 pipes going most of the way back where as the 600/700 header pipe Y's about 4 inches from the block. There is a slight power increase from using it.
Old Feb 24, 2008 | 08:47 PM
jodaanja's Avatar
Will the 800 header bolt right in to my '07 700 EFI? Will it connect to the existing exhaust pipe? Or do I need to buy more 800 exhaust parts to make it work? Also, does use of the 800 header on my '07 700 EFI require me to have my computer altered, such as fuel/air ratio, etc. ??
Old Feb 24, 2008 | 09:57 PM
heller1's Avatar
You will have to get the Header pipe, which will bolt right up to your motor. You will have to remove your "Y" pipe that is on there now. You will also need the heat sheild kit. Polaris sells this as a kit and has everything you need to bolt it on.
Header pipe- 1261445-029
(3)Heat shields-
5244014
5248703
5248702
Header to cylinder gasket- 5811511
Header pipe to muffler seal- 3610047
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
Bigtwin700
Sep 9, 2015 09:32 AM
