HELP!! Starter questions
Old Feb 23, 2008 | 08:28 PM
TtOrMaMnY's Avatar
Default HELP!! Starter questions
Hi guys, I just bought a 2000 Wolverine and the electric starter doesn't work. The pull start works just fine though. The seller told me it was the starter solenoid but i figured i would double check with the forum.
I took a flat head and jumped the starter solenoid + and - and it turned over and the starter turned over but very weak. When I press the electric start button it doesn't do anything.
What you guys think?
**CORRECTION**.
I went outside and tried it again awhile ago. when the button is pressed, all you hear is a clicking sound coming from the starter?
new starter?
Thanks
Old Feb 23, 2008 | 08:40 PM
asdfgh1's Avatar
maybe a short check threw the wires and make shure nothing is unplugged
Old Feb 23, 2008 | 09:02 PM
hondabuster's Avatar
Have the battery load tested, and check the connections at the battery, for cororsion
Old Feb 23, 2008 | 10:15 PM
recon99's Avatar
It's not the battery, at least that's not the reason why nothing happens when the button is pushed. You'd at least get clicking if the battery was causing the problem, as it is known that the battery is holding at least some power.
It could be a number of things. THe first thing I would check is that you're getting a signal voltage to the solenoid when you press the starter button. The small wire that goes into the solenoid should have about 12 volts between it and ground when the button is pushed, then of course 0 volts with the button released. If you're getting voltage there like you're supposed to I'd say that most likely it is the solenoid.
Old Feb 24, 2008 | 04:36 AM
TtOrMaMnY's Avatar
**CORRECTION**.
new starter?
Old Feb 24, 2008 | 12:43 PM
recon99's Avatar
Are you sure the clicking sound is coming from the STARTER and not the solenoid? Solenoid is under the fender by the battery...
Old Feb 24, 2008 | 02:38 PM
TtOrMaMnY's Avatar
recon99 your right.. it is coming from the solenoid. when i hold down my start button i hear it clicking and once in a while the motor sounds like it wants to crank over.
Old Feb 24, 2008 | 03:13 PM
recon99's Avatar
Tap on the starter a couple times with a wrench or something.
Also check the connections on the battery terminals, solenoid, starter, and grounds for corrosion and that they're tight.
If all is good there then i'd go get that battery load tested. When a battery gets too low it will still turn the motor over slowly if you jump across the solenoid. but just holding the button won't crank it over because the voltage drop when the starter engages takes away the power than the solenoid needs to hold the circuit closed.
Old Feb 24, 2008 | 05:23 PM
TtOrMaMnY's Avatar
thats wierd.. so i went outside and cleaned all the corrosion and its still clicking at the solenoid and starter barely going. i put jumper cables to it and it still makes that noise but the starter turns over the motor and starts on occasion. 80% of the time though with jumper cables to the battery it will still click from the solenoid and start on occasion.
Old Feb 24, 2008 | 05:24 PM
qsportgoat's Avatar
you could jump a wire from battery to the starter port, if it turns over then it could be solenoid or something else in route.
