Width of after market tires on stock wheels
Old Feb 26, 2008 | 08:19 PM
JmacBri's Avatar
Default Width of after market tires on stock wheels
My wife has an 06' Sportsman 700 that is completely stock.... She likes to go mudding... A LOT. What is the widest tire that will fit on the 12x7 wheels? I hope you can go 1 inch larger than stock. I think the stock tires front are 26"x8"x12" and rear is 26"x11"x12".
We were looking hard at the Mud Wolf tire as it looks really cool but we can't find anyone to talk to yet that have bought them.
thanks for any help, we're kindof new to this.
Jamie
Old Feb 27, 2008 | 10:40 PM
JmacBri's Avatar
No one knows??
My dealer told me today I could go 1 inch wider and taller on the stock wheel.
Old Feb 27, 2008 | 10:50 PM
sjbr549's Avatar
try to get a stock size tire for performance. bigger tires take some power away unless you put a clutch kit in. then i would go 27" or 28" tall on 14" rims maybe a lift kit
Old Feb 28, 2008 | 12:56 AM
j-rock's Avatar
I'm currently using a set of Greenballs.Size as follows...26x10x12 and 26x12x12.ample clearence,ample power.07 700sp
Old Feb 28, 2008 | 11:24 PM
JmacBri's Avatar
thanks, so J-rock your tires fit with no rubbing? We were planning on the same idea as you only 9" wide fronts.
Jamie
Old Feb 29, 2008 | 12:09 AM
yearight's Avatar
I just put on 27x9x12 front and 27x11x12 on rear. They are ITP mudlite XLR's. the front tires rubbed on the tie rod ends, so I unbolted the outer tie rods and moved them to the bottom side of the bracket and they work fine. My buddy liked it so much he ordered a set and had them mounted on his factory rims.
I ended up with 2 inches of left just from the tires.
Old Feb 29, 2008 | 12:27 AM
heathlight's Avatar
I went from stock to Swamplites on my 06 500 Sportsman (Late....Stolen!lol) I definetely needed 1" wheel spacers, which i wasn't too keen on. They WILL rub on the tie rod boots! The size I had on the fronts were 26x9x12, and the rears were 26x12x12. (The rears were totally fine!) The guy at Polaris said they would work fine........he was wrong! If you do not mind the extra 2" total width, than there is no problem. The only other option is going to after market rims that have an offset to compensate for the wider width rim and tire. Oh yes by the way those swamplites have to be one of my favourite tire for everything. The only other tire that I am looking at are the new Maxxis Zilla's. They are LIGHT!
slowgsxr97
Mar 18, 2022 03:40 AM
metal249
Jul 28, 2015 09:35 AM
Jul 24, 2015 11:57 AM
rcappie4
Jul 18, 2015 07:51 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
