polaris parts
Old Feb 28, 2008 | 03:13 PM
big_kid's Avatar
Default polaris parts
anyone know the ifference between these two parts. 2201115 an 1590237
Old Feb 28, 2008 | 04:00 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
not sure what you mean maybe if there interchangeable or not. heres- 11 2201115 KIT,RELUBE BEARING (Incl. 18,27-29 from a 99' explorer 300 and the other has differnt fitting bikes- 11 1590237 BRG.ASM,O/P SHAFT . from a magum,explorer, 6x6 and so on. looks like the same part w/ differnt applications.
Old Feb 28, 2008 | 05:53 PM
big_kid's Avatar
yea, this is the bearing support for the transmission output shaft on my 97 express. (mounts on frame just behine rear brake rotor) book says part 1590237. also part 2201115 if built after january of 97. mine was built jan 14, 1997 so witch one...??? mine has a bushing not a bearing. i was wanting to know if the later has a bearing, then i will get that one....
the letter in the alphabet between C & E stop working on my computer, sorry for the confusion...
Old Feb 28, 2008 | 06:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
w/out going back and looking on the parts look up to compare, i would guess if they changed it mid year it was to put an updated or better part in. chances are the bearing one would fit and be way better. the 1590237 number was used in many differnt bikes so im guessing the newer pn would be the same fit but a better part.
Old Feb 28, 2008 | 07:09 PM
ftwflh's Avatar
If you are talking about the output shaft on the older chain drives yes the bearing will inter change with the bushing type.
Old Feb 29, 2008 | 10:34 AM
big_kid's Avatar
thats what i thought but knowing my luck i get the bearing style & it will not work...
seems they make a change just before they went to shaft front assist...
thanks for the help...
Old May 26, 2010 | 11:38 PM
6x6rider's Avatar
Does anybody know if I can take an ignition switch off of a '93 big boss 6x6 and put it on a '97 big boss 6x6?
Old May 27, 2010 | 05:58 AM
ftwflh's Avatar
Those will interchange too
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
