what cause this???
Old Feb 29, 2008 | 03:56 PM
dominicano3o5's Avatar
Default what cause this???
ok i have a 45mm crank and a 52mm airsal bore with 28mm koso carb "main jet 135 and plot jet 50" and a Blue cdi box and coil . ok When i first built the motor did a hole on top of the piston then i got a other new piston and it did that same thing again it Keep blowin a hole on top of the piston it not hittin the head or and thing.. what cause that to happen ????
Old Feb 29, 2008 | 04:27 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
You are running very very lean. Need to richen up the main jet a few sizes. Or you have a leak somewhere between the carb and the engine and its letting in air leaning the fuel to air mixture.
Old Feb 29, 2008 | 04:32 PM
i don see no leak no where... Can't be the timming CDI BOX?
Old Feb 29, 2008 | 04:36 PM
KTM Patrol
Former Chinese POW!
<div class="FTQUOTE"><begin quote>Originally posted by: dominicano3o5
i don see no leak no where... Can't be the timming CDI BOX?</end quote></div>
Maybe if the timing was advanced a lot it would ping enough to hole a piston but I would think you would hear it ping and let off.
My son burnt a hole in 2 pistons on his WR 250. Both times it was while he was in the dunes running wide open. first time he blew a head gasget just as it leaned out, 2nd time it was because of a blown base gasget.
Old Feb 29, 2008 | 04:37 PM
EdKatt's Avatar
It could be the timing
Old Feb 29, 2008 | 04:40 PM
So i should just used my stock Cdi box and coil...
Old Feb 29, 2008 | 04:42 PM
KTM Patrol
Former Chinese POW!
What did the spark plug look like?
Old Feb 29, 2008 | 04:55 PM
round the hole on the piston it look gold and White.. on the Sp it White
Old Feb 29, 2008 | 04:56 PM
KTM Patrol
Former Chinese POW!
White is lean, still it could be caused by the timing being off. Have you checked the timing?
Old Feb 29, 2008 | 04:57 PM
Can it be That the piston dose not have the holes on the side of the piston for the Intake??
