Rubicon stalls when pointing downhill
Old Mar 1, 2008 | 12:03 PM
RSeb's Avatar
Default Rubicon stalls when pointing downhill
This happens at the worst possible times. If I am in a situation where I am forced to idle for several minutes while pointing down a fairly steep hill, my Rubicon stalls. It will not restart until I get it to level ground. This usually involves having to get to the bottom of the hill in neutral with no engine. Scary.
This has happened regardless of how much fuel is in the tank, so I don't think it's a vent problem.
Any ideas on A: what is causing this, B: how to prevent it, or C: how to restart without having to get to level ground?
Old Mar 3, 2008 | 09:11 PM
RSeb's Avatar
Bump to the top.
Anyone?
Old Mar 4, 2008 | 04:38 AM
Malachi's Avatar
Depending on how steep the hill is, you probably have all the fuel to the front of the tank so the petcock is starving. It idles till the float bowl is empty.
Maybe try switching to reserve would help? But will only help if theres enough gas in the tank to reach that opening also.
Old Mar 4, 2008 | 09:31 AM
deanz400's Avatar
float might be sticking
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
