86' 200sx motor problems
Old Mar 2, 2008 | 02:56 AM
Malachi's Avatar
Default 86' 200sx motor problems
Hi all, first time posting but been lurking for a while now. Love this site. It's full of great info!! Was hoping someone might be able to help me out now.
I just picked up a 200sx 2 weeks ago thats been sitting outside for 3 or so years.
I cleaned, greased and tuned as best I could and got the thing running for 2 days.
Went to start it up last night and got one pull out of it when it froze up on me. I tore the top end off of it this morning to find the exhaust valve snapped in half laying on top of the piston. Now it needs some new parts and can't for the life of me find internals for this motor. Anyone know of a parts supplier for these older engines other than ebay?
It was actually a fun little toy for the 2 days we got to play with it. I wouldn't mind getting it up and running again if it's not going to cost me an arm and a leg.
I also need to get a service manual for it or atleast some torque specs for the motor. Is there an outlet for the manuals?
Old Mar 2, 2008 | 06:09 AM
125dillmatt's Avatar
hows it going well i no how you feel i have a 125 and a 200m and i kinda have the same problems my valve broke just like that on my 125 a screw came out the choke in the carborator and broke it i shop at a place by my house they cell a lot of that kinda supplies i m going Monday to pick up new timing chain and sprockets for the head they sell every thing for those kinda things this place is called winners cycle i no they have a website you can purchase from i will find it for you if you want it but watch out your valve could of broke because its bent or needs a new shock thats on the other side by the cam shaft at the top of the engine send a private message for feed back if you want
Old Mar 3, 2008 | 01:03 AM
Malachi's Avatar
Yeah, I'm not sure what broke the valve yet. The valve spings and guides look to be in decent shape still.
I'm starting to think the "homemade varnish" from the old gas had something to do with it. I had to clean the carb 3 times in 2 days because of the residue left behind.
Thought I had the tank clean. Started with deisel fuel, then switched to regular gas and left the tank in back of my truck for a day while I drove to and from work for a couple hundred miles letting it slosh around. I then drained it and repeated that step. But I still was getting a nasty residue on the throttle sleeve and inside the carb.
Anyone have a better idea for removing the old bad gas from the tank?
I think I'm going to try muriatic acid and water treatment if I can find some parts for this thing. But maybe there's a better solution?
Dillon, I did a search for winnercycle, but didn't look like they had a way to look up or purchase parts over the internet.
Old Mar 3, 2008 | 02:11 AM
they do but i dont thinks its there name i no they do iim going there tomorrow and i will get it ......try soaking the carb completely under a metal cleaner or some type of residue remover but remove the floater and let it soke for a day or to than wipe it down and clean it......... i wouldn't yous diesel fuel just soap and water and let it dry out should work with a water hose also i would get a filter for you gas lines so it do sent go into the card
Old Mar 3, 2008 | 03:09 AM
Malachi's Avatar
Well the carb isn't the problem. Cleaning with carb cleaner did the trick really well on it.
I'm more worried about the tank it self. I did put an inline filter before the carb after the second cleaning. It didn't seem to help much, other than let me see the crud moving thru the lines. heh
I did just find an E-bay seller who has all the items I need for this rebuild, but would rather not buy thru E-bay if I don't have too.
So if you could get that website addy, it would be greatly appreciated!
Old Mar 3, 2008 | 01:20 PM
STANG302's Avatar
Contact G&H Discount Atv Supply. They also sell services on ebay. I had them rebuild the head on my 200sx about six months ago. They put all new valves, springs and retainers in. They did a great job and I recommend them highly! On top of that I got a cam from Web Cams. Max over bore piston and my jug bored through a local atv shop. The old quad is pretty snappy now!
Hope this helps.
Old Mar 3, 2008 | 01:34 PM
malachi are you talking about the atc 200 sx or the fourtrax 200sx
Old Mar 3, 2008 | 10:05 PM
Malachi's Avatar
Stang302, Thanks for the info! I'll look them up. If you don't mind me asking, what did you pay for the top end rebuild?
I went by a local shop today and got some prices on most the parts. Suprised Honda still stocks most of this stuff! Little pricey but still available.
Dillon, This is a 4 wheeler.
Old Mar 3, 2008 | 10:13 PM
ok im just was checking because Honda made a 200sx 3 wheeler and a 200sx 4 wheeler
Old Mar 3, 2008 | 11:27 PM
STANG302's Avatar
All together with the head rebuild, Web cam, bore and piston it ended up running around 450-500. With myself doing all the work. I also picked up a cobra exhaust a couple years ago for about 125.
Top end: 150.
http://cgi.ebay.com/ebaymotors...hash=item330216230900
Head: 125
http://cgi.ebay.com/ebaymotors...hash=item220066018875
So you could do it cheaper as long as your cam and cam bearings are still in good shape.
