trx450r mods, performance
Old Mar 4, 2008 | 05:45 PM
ivotaw12's Avatar
Default trx450r mods, performance
i have a complete exhaust system, open air box with k&n air filter, and a rev limiter. i still have a hard time beeting the yfz with anything done to it. what mods should i do to help me beat them. i would also like more top end...
Old Mar 4, 2008 | 05:54 PM
-Gary-'s Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ivotaw12
i have a complete exhaust system, open air box with k&n air filter, and a rev limiter. i still have a hard time beeting the yfz with anything done to it. what mods should i do to help me beat them. i would also like more top end...</end quote></div>
I would get a cam. You would be surprised at how easy they are to change...
Old Mar 5, 2008 | 12:06 PM
ivotaw12's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: -Gary-
I would get a cam. You would be surprised at how easy they are to change...</end quote></div>
like i could do it in my garage with just a regular set of tools
Old Mar 5, 2008 | 12:20 PM
lefty1's Avatar
HRC Kit!!! Should put you up around 55HP
Old Mar 5, 2008 | 12:36 PM
-Gary-'s Avatar
like i could do it in my garage with just a regular set of tools</end quote></div>
Yeah, it's a LOT easier than you think. Do you have a manual for your quad?
Old Mar 6, 2008 | 12:46 PM
ivotaw12's Avatar
i dont, but wouldnt a hot cam come with instructions...
Old Mar 10, 2008 | 10:04 PM
DWill58's Avatar
It is very easy. Take off the Rear Plastic (6 screws) and the seat. Then remove the gas tank (you'll need to remove 4 screws from front plastic and 2 from the gas tank as well as the straps). Don't forget to turn your gas off and then disconnect the gas line from the tank to the carb. Loosen the two clamps on the carb (1 to the air box and 1 to the motor) in order to get the carbeurator out of your way. Then remove the 3 bolts on top of the motor and pull the cover off and you'll be staring at the Cam/ rocker / springs / timing chain. Remove the 4 bolts and take pressure off the timing chain tensioner to remove the cam (while sliding the timing chain off of the cam gear. Repeat in reverse order to reinstall new cam.
Customer Service #1
May 15, 2020 08:46 AM
Sep 30, 2015 01:37 AM
Sep 23, 2015 06:23 AM
01ssls1
Sep 22, 2015 06:50 AM
PrairieDog126
Sep 16, 2015 01:33 PM
