2000 scrammy 400
Old Mar 5, 2008 | 03:19 AM
white_scramby's Avatar
Default 2000 scrammy 400
Hey can anyone help me out? I just bought a full fmf exhaust pipe. I was on their site looking for jetting specs and the specs they gave said noting about oil injection and only mentioned oil/mix gas in the directions. Do i have to cut off my live in manitoba Canada...if anyone can reccomened som jetting ideas.
Thanks!
Old Mar 5, 2008 | 09:13 PM
ScramblerX's Avatar
Go up a couple sizes then do a plug reading. Better to be too rich to start than to lean it out.
Old Mar 5, 2008 | 10:00 PM
sprinter10's Avatar
idk if you would have to cut the oil injection or not im sure other people do tho.
Old Mar 5, 2008 | 10:21 PM
03scrambler500's Avatar
i would think that the oil injection system could be left they way it is. Alot of people take it out just for a piece of mind though. Kinda a pain to mix all the time but i think it would be worth knowing you always have oil getting to you engine. I'm not a 100% sure about this though. But i do know any heavly modded polaris 2 stroke always is premix. Good luck.
Old Mar 5, 2008 | 11:21 PM
ftwflh's Avatar
Start jetting at a 280 this should be very rich.Start dropping until you get a clean sound with no blubbering or loading up.then check plug.You should end up between a 260 and 240.
LEAVE THE OIL INJECTION ALONE it wil be ok if it was working before it wil still work with a pipe.
Old Mar 6, 2008 | 12:28 AM
ScramblerX's Avatar
That fmf pipe isn't going to change much, it will barely even require a jetting change.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
