1992 Honda Fourtrax help!
Old Mar 7, 2008 | 12:18 PM
onealjc's Avatar
Default 1992 Honda Fourtrax help!
Hello all,
Just recently puchased this atv after it had been sitting for sometime, i have had the carb professionaly cleaned, replaced oil and filter, the air filter, and fresh gas. However it runs fine when choked full or half way, but when i take the choke off it will die after 5-10 seconds. Any ideas or advice?? Thanks
Old Mar 8, 2008 | 09:59 AM
snorulz's Avatar
sounds like the carb needs adjustment. Did the professional reinstall the carb or did you? If he did then he should make the adjustments to get it to run right.
Old Mar 8, 2008 | 10:48 AM
QWODER's Avatar
May just need to be idled up.should be a screw on the carb somewhere that you can turn and it will make your engine idle faster.You wont have to turn very far for it to idle faster.
NewGuy2481
Oct 6, 2015 05:54 AM
rgjackson
Sep 17, 2015 11:21 AM
stcspiderman
Sep 13, 2015 05:15 PM
Steeldon
Sep 8, 2015 10:51 AM
Jason Campbell
Sep 7, 2015 02:25 PM
