Where Can I find 12 Volts?
Old Jan 16, 2001 | 12:42 PM
Joem's Avatar
Hi All,
I've got a '01 polaris magnum 325. I need to hook up a 12V accessory, is there an easy way to get this without splicing the existing wires?
Old Jan 16, 2001 | 01:12 PM
Bill.Ciliberti's Avatar
You can be sure to get 12 volts by running a hot/ground wire directly from the battery terminals.
Bill
Old Jan 16, 2001 | 06:20 PM
P.J.'s Avatar
Don't forget an inline fuse (properly sized) if you go directly to the battery.
Old Jan 17, 2001 | 09:47 AM
kevin_staton's Avatar
Why not use the accessory jack on the left side (looking from the back) right above the rear wheel?
I went to Walmart and picked-up a 12-volt cigarette lighter type adapter with a spring-loaded cover door and pigtails, mounted right above the tail light and used the crimp-on in-line connectors to power it. All said, about $9 and 10 minutes.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Hatrackr
Aug 11, 2015 09:03 PM
TheHood
Aug 8, 2015 05:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
