Error code 51,52
Old Mar 10, 2008 | 05:33 PM
yearight's Avatar
Default Error code 51,52
My buddy has an 07 sp 800 he probably has 100 miles on it and yesterday it starts sputtering and idling ruff.
Today I stopped over and showed him how to do the self diagnostics.
It showed problems with both injectors.
Has anyone else had this problem arise and if so, what was the solution?
Old Mar 10, 2008 | 05:46 PM
OIown12's Avatar
Has he checked the battery voltage. Could be low, maybe?
Old Mar 10, 2008 | 07:57 PM
JCDEYO25's Avatar
I bet it's one of the plug wires to the coil......Possibly worn thru and arching to the frame...
John
Old Mar 11, 2008 | 10:55 PM
JCDEYO25's Avatar
yearight.....
Any news as to the problem?????/
John
Old Mar 12, 2008 | 09:47 AM
yearight's Avatar
yes, he is pulling apart as we speak.
The coil mounting bolt doesn't have a good ground causing an arc.
I posted this problem on a few sites and come to find out, a few guys have had the same problem.
The problem isn't with the coil, it's just the mounting bolt.
A few guys have also had a problem with code 41,46 I think those were the codes. The code if for the barometric pressure sensor. The sensor is fine , but the connections turned out to be bad.
Old Mar 12, 2008 | 09:59 AM
JCDEYO25's Avatar
Yea I've heard of the bad ground too before just forgot to mention it......Glad you guys found the problem..
John
Old Mar 12, 2008 | 10:35 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: yearight
A few guys have also had a problem with code 41,46 I think those were the codes. The code if for the barometric pressure sensor. The sensor is fine , but the connections turned out to be bad.</end quote></div>
41- is the air, and 46-is the barometric.
Sw00p
Sep 24, 2015 02:50 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
