Raptor 660 blow by / back pressure
While troubleshooting a top end power reduction, I'm only coming up with 95 psi on a compression test (hot engine, throttle wide open, battery up and cranking fast). Later, I decided to test the ignition timing and was shocked at the amount of blow by coming out of the hole you check timing at. I assume this is where all my compression is going - nowhere. How much airflow should you get with this timing plug out and the engine idling? The bike will not idle but only for a few seconds with the plug out.
bzdok1234
30
Feb 23, 2016 01:55 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
