2007 450 wont start
Old Mar 12, 2008 | 09:31 PM
ftwflh's Avatar
Default 2007 450 wont start
I am working on a 2007 450 Sportsman.It has fire at the plug and will start on either for a second.It has gas but not getting gas to the carb.I swapped fuel pumps with my spare and the same thing.
What I think next will be to set the valves.Hope this works
Any other Ideas?
Old Mar 12, 2008 | 09:41 PM
drlang's Avatar
A compression check will also confirm the valve settings. How is the fuel pump driven?
Old Mar 12, 2008 | 09:51 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
First ....check to make sure the fuel shut-off under the front fender between the wheels is letting fuel to the carb..............I know but had to ask!!!...Caper..........
Old Mar 12, 2008 | 11:15 PM
ftwflh's Avatar
It would be easier to set/check valves than to get a comp gauge in the plug hole
Already checked the fuel valve.
Old Mar 12, 2008 | 11:43 PM
rmtlle's Avatar
My son also has a sportsman 450 2007 and it won't start. It also has gas, good battery ... but does not turn over. Anyone have any suggestions to try? Or what could be wrong? Any help or advice would be greatly appreciated.
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
bogie ben
May 30, 2015 04:10 PM
1000gade
May 27, 2015 12:37 PM
Icedevice
May 25, 2015 08:38 AM
MrElussive
Nov 19, 2000 01:51 AM
