dinli jp50
Old Mar 13, 2008 | 01:35 PM
brycat22's Avatar
Default dinli jp50
When giving it throtte the is a hesitation or slow response before it kicks in and goes once it takes off runs pretty good. This is a 2 stroke. I have replaced the plug looked like it may be running a little rich. Any thoughts would be helpful.
Old Mar 13, 2008 | 05:37 PM
rjdad's Avatar
Default dinli jp50
If the carb is set too rich, what you'd describe will happen. I would try and lean out the carb to see if that takes care of the problem.
Old Mar 13, 2008 | 05:43 PM
brycat22's Avatar
Default dinli jp50
That was my next step, to try to make it run a little leaner. Been trying to find info on adjusting the carb. I do not want to cause more problems.
Old Mar 14, 2008 | 11:16 AM
rjdad's Avatar
Default dinli jp50
http://www.dinlisales.com/products/jp_50_pics.html
Here is a website that has a parts and service manual online. The manuals were photo copied and are very poor in quality. I was looking for carb adjustment instructions and did not find anything. Give them a call and see if they can help.
Old Mar 14, 2008 | 01:02 PM
brycat22's Avatar
Default dinli jp50
Made adjustments to the carb but did not seem to help the throttle response. Decided to check compression but not sure if pressure gauge was good. Compression showed 20 psi. I would think this bike would not run with that low of compression. The bike seems to run fine after it kicks in. Any thoughts anybody.
Old Mar 15, 2018 | 12:05 AM
CHPHONDA's Avatar
Default JP50 Walbro Carburetor
dinli jp50-img_20160905_174542215.jpgI realize this is a 10 year old thread but I imagine there are still a few JP50s out there that are running poorly. Mine had run badly for years. Taking the carb apart and cleaning it seemed to fix it for a bit but the JP always reverted back to its habit of running very lean and would only run with the choke partially on and then run not very well. I purchased a carburetor online, probably from China, that claimed it fit the JP as well as other Dinli models. It didn't come close to fitting!
I then tried to find a rebuild kit for the Walbro. I ordered this kit.
Walbro Repair Kit Part # K10-WJ
It did the trick. The little JP runs as good as ever. My grandkids, nieces and nephews are very pleased. I think the main problem was the small diaphragm had gotten stiff and wasn't letting sufficient fuel into the engine. The kit only cost about $8. Wish I'd thought of it sooner.
Click image for larger version
ID:	28746dinli jp50-img_20160905_191158625.jpg
Old Jan 11, 2022 | 10:09 AM
Fang502002's Avatar
Originally Posted by CHPHONDA
Attachment 28746I realize this is a 10 year old thread but I imagine there are still a few JP50s out there that are running poorly. Mine had run badly for years. Taking the carb apart and cleaning it seemed to fix it for a bit but the JP always reverted back to its habit of running very lean and would only run with the choke partially on and then run not very well. I purchased a carburetor online, probably from China, that claimed it fit the JP as well as other Dinli models. It didn't come close to fitting!
Attachment 28746Attachment 28747
I know this is an old post - but I am having issues with the original Walbro carb (WJ-98) - I bought the rebuild kit - fitted it but the carb still hesitates and over fuels... how do I tune these carbs? I see it has two smal red caps on the side - turns just a few mm in either direction - tried everything and same result ...
Old May 23, 2022 | 03:25 AM
Fang502002's Avatar
oki - so after I broke out the factory fitted red caps - was able to tune the carb ...
Ashley S
Feb 18, 2024 08:56 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Fizzy
Mar 19, 2011 08:10 AM
oldsandman
KTM
11
Jan 21, 2004 01:31 PM
Harw
KTM
14
Dec 19, 2003 09:08 AM
