warrior stator cover
Old Mar 14, 2008 | 01:09 PM
wwarriorrider350's Avatar
Default warrior stator cover
ok, i just tried to take the left cover of the engine off, i took out the 4 screws and pulled it outward when i did it opened about a centimeter(if that) and oily looking stuff came out. it might of been oil im not forsure yet.
can anyone tell me whats going on please im totally lost
Old Mar 14, 2008 | 01:29 PM
Default warriot stator cover
anyone???????
Old Mar 14, 2008 | 01:34 PM
justhanginout's Avatar
go online to ebay and search of the service manual you can DL them for like 6 to 9 dollars. as far as oil coming out i'm not to familular with the warrior but i know on my wolverine when you take off the cover it should just be flat and have a plug for checking timing and also a bolt that goes into the crank shaft.
Old Mar 14, 2008 | 01:50 PM
pmcc37's Avatar
oil shouldn't have come out. that side should be sealed, unless you have a cracked case.
Old Mar 14, 2008 | 01:57 PM
maybe...
soon as i pulled to try and take the cover off it poored out...
Old Mar 14, 2008 | 02:18 PM
pmcc37's Avatar
but that would explian the bad stator. if it can't conduct electricity, but a big problem.
pull it all the way off and see if you see a crack, it may be able to JBweld it, but sounds like bigger problems.
Old Mar 14, 2008 | 02:25 PM
it wont come all the way off. it feels stuck after i pull it about a centimeter off
Old Mar 14, 2008 | 03:10 PM
pmcc37's Avatar
i'd see if you can get a manual on line and download it. I don't know why it is sticking, i'm at work or i'd look at my manual and let you know. if your still having trouble tonight i'll try and check and get back on here n let you know.
Old Mar 18, 2008 | 09:05 PM
woodsjunky's Avatar
pull its a magnet
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
carid
Sep 14, 2015 03:40 PM
johnny1982
Sep 13, 2015 07:41 PM
