warrior case
Old Mar 16, 2008 | 07:45 PM
mfglideman's Avatar
Default warrior case
Does the left side case have a gasket? I should say is it supposed to have a gasket? Its a new bike to me, when sitting on the bike I look down and can see a gap on the outer cover. I can see clear through to the ground
Old Mar 16, 2008 | 11:07 PM
beefy46172's Avatar
Loves To Ride!
Left side, you are talking about the circular panel with the Yamaha logo on it, correct? Just has a couple allen-head screws on it, if we are thinking of the same part. It does not have a gasket.
Old Mar 16, 2008 | 11:10 PM
justhanginout's Avatar
http://www.powerpartsplus.com/...wbybrand/default.aspx
go find ur bike and look it up
Old Mar 16, 2008 | 11:29 PM
Raptor450's Avatar
If you have a gap that big and it's not leaking oil, then either you don't have any oil left or you don't need a gasket there. You have to be referring to the plastic end cover, it's not actually an engine case.
Old Mar 16, 2008 | 11:32 PM
beefy46172's Avatar
Loves To Ride!
<div class="FTQUOTE"><begin quote>Originally posted by: Raptor450
If you have a gap that big and it's not leaking oil, then either you don't have any oil left or you don't need a gasket there. You have to be referring to the plastic end cover, it's not actually an engine case.</end quote></div>
Thats what I was thinking. All it does is cover the end of the flywheel nut or whatever that thing is called.
Old Mar 17, 2008 | 12:02 AM
yeah where the plug to check the timing is...
Old Mar 18, 2008 | 08:49 PM
woodsjunky's Avatar
normal just a plastic cover to protect the flywheel nut
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
WilliamBos
Sep 22, 2015 04:07 PM
01ssls1
Sep 22, 2015 06:50 AM
