87 Yamaha warrior
Old Mar 16, 2008 | 08:21 PM
exbro45's Avatar
Default 87 Yamaha warrior
Warrior wont stay at TDC. Anybody heard of this?
Old Mar 16, 2008 | 09:18 PM
warr87ior's Avatar
Default Yamaha warrior
what is TDC...?
Old Mar 16, 2008 | 09:35 PM
beefy46172's Avatar
Loves To Ride!
Top dead center. Piston at top of stroke. Do you mean it won't stay in time, or what?
Old Mar 16, 2008 | 09:46 PM
exbro45's Avatar
Yeah i match up the Marks then turn it over and it don't fire then i check the marks again and there off.
Old Mar 16, 2008 | 11:16 PM
Raptor450's Avatar
That would be the timing chain is slipping on the timing gear. Or you can have TDC with the cam 90 degrees off (upside down). The crank rotates twice for every one time the cam rotates.
Old Mar 16, 2008 | 11:19 PM
beefy46172's Avatar
Loves To Ride!
<div class="FTQUOTE"><begin quote>Originally posted by: Raptor450
That would be the timing chain is slipping on the timing gear. Or you can have TDC with the cam 90 degrees off (upside down). The crank rotates twice for every one time the cam rotates.</end quote></div>
How would that be possible with the dowel pin and notched sprocket on the Warrior? (Not being a smartass, its late and my mind may not be working properly)
Anyway, your timing chain is definately slipping. Does it have adequate tension? If so, you need to inspect the gear on the camshaft and if it looks good, then we could be talking a bad lower sprocket.
Old Mar 16, 2008 | 11:40 PM
Raptor450's Avatar
Maybe the piston is acually at BDC with the cam in the TDC position.
Old Mar 16, 2008 | 11:42 PM
exbro45's Avatar
Well then its the lower thats gone because the top looks good and the tensioner looks good too. I already looked on line for hours and there is no way to get just the lower sprocket, i have to buy the whole left side crankshaft. Unless that sprocket can be pulled off. Thats as far as i got.
Old Mar 17, 2008 | 11:35 PM
beefy46172's Avatar
Loves To Ride!
Maybe the piston is acually at BDC with the cam in the TDC position.</end quote></div>
That is a possibility.
Exbro, you have pulled the little cover on the left hand case and matched it up with the T as well as the mark on the cam sprocket with the notch on the cam cover seat, right?
Old Mar 18, 2008 | 09:49 AM
pmcc37's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: exbro45
Yeah i match up the Marks then turn it over and it don't fire then i check the marks again and there off.</end quote></div>
Do you match up the marks with the tensioner on or off, needs to be off, then put it on and re check it. If its not firing your cam is proabably at BDC like raptor and beefy mentioned, that mark is about 6* dots before the T for TDC
*Don't remember the number of dots or lines, depends on each individual bike.
2quiker
Mar 22, 2022 08:36 PM
Sep 17, 2015 03:06 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
