yfz450 cases
Old Mar 17, 2008 | 12:48 AM
markymark116's Avatar
Default yfz450 cases
i have an 05 yfz450 quad. just threw the chain, and cracked the case. my buddy has a set of cases off an 06. one guy is telling me they will fit, and another is telling me that 04-05 is different than 06-07. before i rip this motor out, does anyone know for sure?
Old Mar 17, 2008 | 01:36 AM
anyone?
Old Mar 17, 2008 | 01:42 AM
FordNut5's Avatar
I think they changed the CC's somewhere in that time frame, but i don't think that would affect the case any. So i think it would work.
Old Mar 17, 2008 | 01:47 AM
i know for a fact it's the exact same piston
Old Mar 17, 2008 | 01:48 AM
the mounting bolts look like thay match up with the frame too. i'm just afraid the guts won't match up
Old Mar 17, 2008 | 02:51 AM
viper5's Avatar
As far as I know they are the same
Old Mar 17, 2008 | 10:32 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
<div class="FTQUOTE"><begin quote>Originally posted by: markymark116
i know for a fact it's the exact same piston</end quote></div>
Yamaha upped the displacement from 439cc to 449cc in '06. I would think they did that through bore but, it is possible the stroke is different. Either way that is something to watch for.
Old Mar 17, 2008 | 12:37 PM
justhanginout's Avatar
just look it up on an OEM page and see if when you go to order the cover if it has the same Part #.
Old Mar 17, 2008 | 07:04 PM
FordNut5's Avatar
If its the same piston, then the stroke is different, and that could cause you some issues
Old Mar 20, 2008 | 03:18 AM
Sandnutz5's Avatar
Yamaha increased the displacement in 2006 by stroking the crank by 1.4 mm- All the 2004/2005 parts will fit in the 2006 and later cases- you can also install the 2006 and later crank and piston ( same as the 2004/2005) into the 2005 cases-Yamaha has superseded the 2004/2005 case numbers with a 9999 series number which are the same as the 2006 and later cases- I just bought a new set of cases from MR Cycles for $258.00- Make sure you do the 2007 oil squirter mod which will save your crank and rod on the 2004/2005- I found out the hard way -$1500 worth of parts later!!!
flyin-lowe
Dec 1, 2017 03:18 AM
EIF
Apr 20, 2017 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
Sep 23, 2015 06:23 AM
WilliamBos
Sep 22, 2015 04:07 PM
