yfz450 cases
i have an 05 yfz450 quad. just threw the chain, and cracked the case. my buddy has a set of cases off an 06. one guy is telling me they will fit, and another is telling me that 04-05 is different than 06-07. before i rip this motor out, does anyone know for sure?
<div class="FTQUOTE"><begin quote>Originally posted by: markymark116
i know for a fact it's the exact same piston</end quote></div>
Yamaha upped the displacement from 439cc to 449cc in '06. I would think they did that through bore but, it is possible the stroke is different. Either way that is something to watch for.
Yamaha increased the displacement in 2006 by stroking the crank by 1.4 mm- All the 2004/2005 parts will fit in the 2006 and later cases- you can also install the 2006 and later crank and piston ( same as the 2004/2005) into the 2005 cases-Yamaha has superseded the 2004/2005 case numbers with a 9999 series number which are the same as the 2006 and later cases- I just bought a new set of cases from MR Cycles for $258.00- Make sure you do the 2007 oil squirter mod which will save your crank and rod on the 2004/2005- I found out the hard way -$1500 worth of parts later!!!
Sep 23, 2015 06:23 AM
