honda recon 250
Old Mar 17, 2008 | 01:40 AM
real talk's Avatar
Default honda recon 250
i have a 99' honda recon 250 2 wheele drive. while you riding everything is normal and it rides fine but when are stopped you can move the tires back and forth as if something was worn out. if you have any ideas let me know.
Old Mar 17, 2008 | 10:42 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I assume you have checked the lug nuts, and they are tight???
Assuming the above is not the problem, most likely the nuts on the hubs have worked loose. Take the wheels off, pull the cotter pin out of the nut that holds the hub on, and tighten the nut up. If you have let it go to long, you may have stripped the splines on the hubs/axle, which will mean they will have to be replaced ($$$$).
Old Mar 17, 2008 | 11:12 AM
LittleBill's Avatar
if the whole rear end moves and not just one tire, look at the swingarm bolt and see if its sliding
wendal
May 9, 2024 09:29 PM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
stcspiderman
Sep 13, 2015 05:15 PM
Jason Campbell
Sep 7, 2015 02:25 PM
