My polaris has no power
Old Mar 17, 2008 | 12:21 PM
the bayou's Avatar
Default My polaris has no power
Ok well i have a 1992 polaris 350L 2-stroke finally got it running and now NO POWER I have to push it hammer the gas and then jump on and still it barley has enough to pull me around at 3 mph! What could cause this?
Old Mar 17, 2008 | 12:24 PM
sjbr549's Avatar
have you cleaned the carb?
is the reed valve ok?
air filter clean?
is the gas old?
Old Mar 17, 2008 | 12:52 PM
the bayou's Avatar
yes cleaned the carb
wheres the reed vavle?
Air filter is new
Has new gas
Old Mar 17, 2008 | 01:06 PM
sjbr549's Avatar
the reed valve is bolted to the head behind the carb.it acts like a intake valve for 2strokes.the carb boot mounts to it .it's around $40 for a new set of reeds. it helped mine out alot.you can turn them over once and use the other side.the reeds have 3 screws per side holding them on the housing
Old Mar 17, 2008 | 01:27 PM
the bayou's Avatar
could this cause an extreme loss of power like I am having?
Old Mar 17, 2008 | 01:35 PM
sjbr549's Avatar
not sure if it's the fix for you.when i replaced mine it idled alot better and the throttle responce improved greatly. i had something similar to you at w.o.t. it would barely pull me then all of a sudden it would take off wide open. then it would do it all over again. i had some bad gas in it and it gummed up the carb. i had to take it completely apart use carb cleaner and very fine steel whool to polish and clean everything. have'nt had a problem since hope this helps some
Old Mar 17, 2008 | 01:51 PM
02magnum500's Avatar
Gets his share of deer.
not like you would not notice but if you exhaust pipe poped off the joint by the engine it really bogs the engine down...also make sure you exhaust pipe is clean and not carbon filled.
Old Mar 17, 2008 | 02:30 PM
the bayou's Avatar
Keep um' coming guys I like all these ideas now kind of a strange thing when i just have it in nuetral and rev it up once I get past a certain Rpm it revs up a little higher but as soon as I get on it and put it in gear no power at all!
Old Mar 17, 2008 | 04:08 PM
the bayou's Avatar
Is there anyother Ideas out there?
Old Mar 17, 2008 | 05:55 PM
rayf's Avatar
did u check compression?
