My polaris has no power
Old Mar 19, 2008 | 07:08 PM
  #21
ftwflh's Avatar
Default My polaris has no power
ramps make the rear clutch work and it has 3 and they are about $3 each
Old Mar 20, 2008 | 10:15 AM
  #22
the bayou's Avatar
Well I took the reed off and looked down into the engine the bottom of my piston has a bunch of little chunks broken off. I am sure this is what is causing my issue. How hard is it to replace the piston also so is it just running and loosing power where the small hole is?
Old Mar 20, 2008 | 01:32 PM
  #23
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you have a broken piston skirt and pieces are down in the crank area, beware they dont do damage to the crank shaft bearings. if you need to replace the piston, then you will have to have cylinder work done as well by at least honing it if not boring. you need the specs. and need to take it to a machine shop to have it checked. imo.
Old Mar 26, 2008 | 10:41 PM
  #24
KD5EDP's Avatar
I purchased a 96 Xplorer 2 cycle. Didn't have much power. Local dealer thought it might be the driven clutch. Removed clutch and gave it a shake. If it is worn you can hear the beads shake they need to be replaced. What is happening is it is going into high gear too soon. 39.00 later it runs like a champ. Might give it a try.
Reactant
Mar 30, 2022 02:08 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
RedRancher
Jul 10, 2015 06:36 PM
Jul 7, 2015 11:00 PM
tweeder
Jul 5, 2015 01:57 PM
