YFM 350 forum
Old Mar 17, 2008 | 01:55 PM
meathed66's Avatar
Default YFM 350 forum
Anybody know what happened to yfm350central.com? I can't find it now, and it had a lot of really helpful info for yama 350's
Old Dec 2, 2019 | 01:55 PM
Conor Crowley's Avatar
Anyone help me with my YFM 350 Raptor not sitting idle even after a full carb rebuild.
Old Dec 2, 2019 | 02:56 PM
sr.ruedas's Avatar
I assume you mean that it will not idle.
When you cleaned the carb, could you see light thru your pilot jet? These have very small orifices, and often cause this symptom. You also
need to make sure your cold-start valve is clean and operating smoothly. The pilot air screw passage must be clear. If there is any air leak
in the intake manifold or on the carb, that needs to be fixed.
Old Dec 2, 2019 | 03:12 PM
yes I replaced all of the jets to brand new. it used to sit idle but only with the choke on and it would have high RPM, even if I was riding the bike if I came to a stand still I would have to feather the throttle or put some choke on. I replaced the whole inside of the carb and now its not sitting idle at all not even with the choke on. a friend of mine thinks its taking in way too much air than fuel but the idle screw on the carburettor has seized.
its a kind of weird idle screw its attached to like a cable that sit on a little hook like bracket ontop of the carburettor. im just thinking il get a new idle screw if I can but I want to check anything else it could be in the men time
Old Dec 2, 2019 | 03:33 PM
sr.ruedas's Avatar
If I understand you, that is the idle speed set screw with thumb wheel. It is not the idle mixture (pilot) screw. It just holds the throttle open a bit to set idle speed. Posting pix helps.
Your symptoms point to lean condition at idle. Too much air.
Old Dec 2, 2019 | 03:53 PM
thats what somebody else has said there is too much air getting on which is why it wont sit idle not even if the choke is on. this is also causing it not to rev properly. im hoping I can get the idle screw set changed online if I can find a matching one
Conor Crowley
Dec 3, 2019 01:17 PM
leavy30
Oct 31, 2015 06:35 AM
110cc loncin
1) Engine problems..
Jan 3, 2013 11:33 AM
IWL BCNU
Jan 18, 2008 11:03 AM
anth
Mar 3, 2004 11:06 PM
