HPR 730 or stock bore cams and headwork
Old Mar 17, 2008 | 09:58 PM
jimbo5o's Avatar
Default HPR 730 or stock bore cams and headwork
I just sold some vintage stereo equipment on e-bay and made way more than I expected. Since it is like found money I figured I would blow it on the DS.
I am looking for Opinions on which route I should go.
The bike has a pipe Tm45 w/ported intake, woods cdi and 15/42 gearing w/520 chain and sprockets. It is mostly a duner, but carrying my 300 lb
*** up the hill I get beat by most. Looking for more..... I know I'll never be the fastest, but would like to at least be able to challenge those pesky bolt on 450's and rappys.
I am thinking of just getting the 730 and running that till I find some more scratch then doing the cams and porting. Will I see much of a difference with this setup or do I need cams and porting to make the 730 run well.
Or would I be better off doing the cams and having the head ported? would I need to redo the porting should I do the 730 later.
Reliability is a big factor as this is my only bike.
Help me out guys, before I blow this money on something else.
Thanks,
Jim
Old Mar 17, 2008 | 10:51 PM
cynick's Avatar
I personally like the way my stock bore runs, I would think that I would run with the stock bore, way more reliable.
Old Mar 18, 2008 | 01:20 PM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
I think the big bore is the only way to go Jimbo for a big guy you need grunt not rpm I found that out with Marios old stk bore my bike and rider combo was to much BUT when the 730 whent back on, look out [img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 18, 2008 | 01:35 PM
DSengineer's Avatar
Has been here a long time!
I think at your weight you would be happier with the added torque from the 730. I have a stock bore/cams/porting that is a pretty good runner but I only weigh 180lbs.
Old Mar 18, 2008 | 02:23 PM
Halfliter's Avatar
Another vote for the 730. I love mine to death. Mine is done with stock cams and carb. You have the carb so you should have even more fun. Plus, boring it out removes 100 pounds. I didn't weigh the chips but I know it is true after riding it feels that much lighter!!!! Seriously, bang for the buck has to be worth it also. I heard they are cheaper now and I thought I saw you can get a casting and do the work yourself. The only down side is when you beat someone they say it is because of the displacement. If you beat someone with a 650 it is from tuning. More bragging rights.
Old Mar 18, 2008 | 05:42 PM
DSengineer's Avatar
Wow 100 lbs!!! I've got to get me one of those [img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 18, 2008 | 06:38 PM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
i have a hpr730 got it when they were on sale, only has web 109's a 48mm lectron and a mild head port with stock vavles, and she RIPS, this thing is a torque monster. go for the 730
Old Mar 19, 2008 | 05:40 PM
thebigshow's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Halfliter
Another vote for the 730. I love mine to death. Mine is done with stock cams and carb. You have the carb so you should have even more fun. Plus, boring it out removes 100 pounds. I didn't weigh the chips but I know it is true after riding it feels that much lighter!!!! Seriously, bang for the buck has to be worth it also. I heard they are cheaper now and I thought I saw you can get a casting and do the work yourself. The only down side is when you beat someone they say it is because of the displacement. If you beat someone with a 650 it is from tuning. More bragging rights.</end quote></div>
Did i miss something somewhere?? boring out removes a hundred pounds???
man im a pretty big guy too, i tried it with the race head and cams first and it was a great improvement over stock, but if you want the arm ripping grunt, the big bore is the way to go for big guys. wait untill you get both, huge improvement over stock.
Old Mar 19, 2008 | 06:12 PM
DragonDJ11's Avatar
That amazes me since it is just the cylinder and my 5 year old son carries my stock one around for me [img]i/expressions/face-icon-small-smile.gif[/img] He is way stronger then I thought. The 730 from OMW is not a bored out stocker either. It is a new jug casted to hold a larger piston for your greater displacement. The greater compression and light weight OMW pistons give greater revving speed, and yes that does make it feel way lighter.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
