RAPTOR PIPE woes
Old Jan 17, 2001 | 01:32 AM
joeyd's Avatar
Hey guys stilll waiting for my jet kit from white bros..in the meantime i have a problem. I want to ride this sat. but i checked my plug and i am running lean. The plug is white with tiny spots of tan. I really want to ride this weekend. i had a white bros e-series pipe put on by the dealer but of course it wasn't done right. I called white bros and they said that rejetting wasn't necessary. The dealer said they made an external adjustment to the carb. What did they do? turn the air screw? My question is there anything i can do to correct this problem before the weekend aside getting the jets? Is it dangerous to keep riding it like this? I am running 13 discs
Raptor 2001 Blue
White bros e series pipe
Old Jan 17, 2001 | 09:41 AM
RAPTOR1's Avatar
If you go down to 10 or 11 discs it will richen it up. Try 11 1st then 10 if still too lean. I did this until I got the headpipe and finally rejetted it and it work great. That is the nice thing about the e-series you can add or remove the discs to lean and richen the bike!
hope this helps!
mike
Old Jan 18, 2001 | 11:36 PM
joeyd's Avatar
Thanks dude!
Also are you running the anti-seize gel on the bolts? Did you know they make titanium disc also.
WHat jet settings did you run?
Old Jan 20, 2001 | 08:08 PM
fast400's Avatar
i just put a white brothers e- series slip on on my raptor the other day and it runs good, sounds good, but when you're running about a quarter to half throttle and punch it wide open it will cut out badly. i'm thinking it's to lean but haven't checked my plug yet. it will only do it when you punch it. any other time it runs fine. any help is appreciated.
Old Jan 21, 2001 | 11:57 AM
Dblitz's Avatar
How many disc came with your system?
I order mine from moto-man and 12 were
standard.Just wondering if you to order more
or it came with extras.
Thanks
Old Jan 21, 2001 | 04:49 PM
fast400's Avatar
my system came with 12 discs. i checked my plug today and it has carbon deposits on it and the porcelin is light brown on the bottom and about half way up it is white. the electrode is black and around the bottom is black also. i can't figure out what is wrong.
Old Jan 21, 2001 | 09:03 PM
Whit11's Avatar
You might try moving the needles up one slot in the carbs. If that doesn't help(or helps only a little)you'll probably have to get a dynojet kit with bigger jets and thinner needles. My two cents
bmxatv10
Oct 14, 2022 06:23 PM
mrtidy
Feb 3, 2016 05:00 PM
salixair
Nov 3, 2015 08:25 AM
black_thunder
Sep 22, 2015 07:59 PM
greg86hd
Sep 16, 2015 12:32 AM
