Warn rt30 installation
Has anyone installed a Warn RT30 on a 2008 SP800? I am trying to install mine. I have the winch installed. I am now at the point of installing the wiring and contactor. I know these quads are prewired for the winch. Warn instructions say to mount the contactor in the back and I read on here to install it some where in the front.
Help! haha
Help! haha
it goes under the front right fender, there is a small metal shield that is held up by two 3/8's bolts, take that out and you'll find the wires up there. don't forget that you have to hook up the battery positive wire at the battery.
Just finished mine, little of both I used....I mounted it in the front, but did not use the pre-wire, used the warn wires that came w/ my xt30...Not hard at all any ???? just ask, I might be able to help...
Okay...I got it all hooked up. I tore out the polaris prewired hot lead. Ran an new one in the same wire loom. I kept the factory negative wire. I mounted the contactor in the factory location above the wheel. Cut the blue and yellow to the correct length.
Did you mount the wired remote? If so where did you mount the jack for it?
Jeff Roper
Feb 1, 2022 11:48 AM
jrooker6
Apr 23, 2016 07:36 PM
