Ds650 Fuel ratio question with wideband o2
Old Mar 21, 2008 | 10:52 AM
Lhduce's Avatar
Default Ds650 Fuel ratio question with wideband o2
I was thinking about installing a wideband o2 for jetting on my 2006 ds. does any one know what the stock wot fuel ration is 12-13? And what the bike idles at so i can get prefect mix. ive try searching but it seem must ppl take it to dyno. Since ive tune my person 800whp supra with wide band i figure i could do the same with the ds. Any help with the right fuel ratio for the bike would be perfect thanks again guys on my first post.
Old Mar 21, 2008 | 11:12 AM
Sport400inOH's Avatar
The DS is a 4 stroke engine just like your Supra, only it is not turbocharged.
Here is a snipet that I found for ya.
"The Wide Band Commander gives you everything you need to accurately monitor your air/fuel ratio. In most cases the target a/f ratio for naturally aspirated engines will be between 12.8:1 and 13.2:1 whereas supercharged, turbocharged, and nitrous-injected engines will like a richer mixture between 11.5:1 and 12.5:1.
Old Mar 21, 2008 | 11:22 AM
Lhduce's Avatar
Do you have any idea what the ds idles at? 15-16 range. thanks sport400.
Old Mar 21, 2008 | 11:39 AM
As I have never tested it, I do not know specifically. The stock DS carb has the equivalent of an accelerator pump, so I believe the ratio should be in that range of mid 14's to mid 15's
Search for OMR carb mods and read through - That should give you a good idea in terms of baseline settings
Old Mar 21, 2008 | 01:42 PM
Lhduce's Avatar
I wish OMR would check in..
Old Mar 21, 2008 | 03:45 PM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
Link To OMR carb mods.
Old Mar 22, 2008 | 12:26 AM
Lhduce's Avatar
thanks xfreebirdx
Old Mar 22, 2008 | 06:45 AM
DubaiPolaris's Avatar
916 Reaper - Pure Evil Inside!
I use the Innovate Motorsports LM1 wideband to log and tune my DS. I have the O2 sensor located pretty much behind the stock heat shield, and only have it on there for tuning. I tune mine to run at 12.5-13, and it screams. When I had it on the dyno, right around 13 made the most power. Mine idles right at 13.
Chris
Old Mar 22, 2008 | 01:26 PM
Lhduce's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: DubaiPolaris
Chris</end quote></div>
Chris do u mine telling me little bit more about your setup. And do you think egt on the ds really matter that much. let me know thanks.
Old Mar 23, 2008 | 08:32 AM
This is the LM-1 that I use. You have to weld a bung in the header for the O2 sensor. The bung has a cap that you screw into it when not using the sensor. I only use the sensor when tuning. guess you could leave it in there all the time and hook it up to a 2" guage and mount it in the dashboard.
Good AFR is the difference between making horsepower and losing it. The first time I went to the dyno the top end was really rich with an AFR of 11:1. Leaned it out to around 13:1. We picked up 2-6hp in the topend curve on the dyno. We leaned it out a little more, around 13.7:1 and started losing power.
I am by no means an expert on this. I did a lot of reading/research, and testing on my own, and with a dyno. I try to tune mine in at just under 13:1.
Chris
Kyle5050
Dec 13, 2019 04:25 AM
kdg723
Jul 25, 2015 01:20 PM
Aitch
Jul 21, 2015 09:40 PM
Ask the Editor
12
Jul 21, 2015 06:57 AM
Mikea1978
Jul 4, 2015 12:37 PM
