YAMAHA WARRIOR 360
Old Mar 21, 2008 | 11:23 PM
WARRIOR360's Avatar
Default YAMAHA WARRIOR 360
HOW FAST DO YOU THINK A WARRIOR WITH STOCK GEARING, POLISHED & PORTED HEAD, K&N AIR FILTER, BORED TO A 360CC,FMF POWERCORE 4 S/A,
FMF POWERBOMB HEADER,AND 20" REAR TIRES.
Old Mar 21, 2008 | 11:41 PM
warr87ior's Avatar
mine is stock except for the DG rcm2 slip on and it does 70mph so prob like 75ish....?
Old Mar 21, 2008 | 11:45 PM
DeathValleyReaper's Avatar
a stock warrior will run about 55mph. my neighbors warrior is bored .30 over with many other extras and i belive it will only do 72mph. i guess around 60-65mph.
Old Mar 22, 2008 | 12:22 AM
Octane2079's Avatar
What compression are you running with the big bore piston? Also still stock cam?
Old Mar 22, 2008 | 12:47 AM
WARRIOR360's Avatar
YES I HAVE A STOCK CAM, 10:1 Compression. It runs premium gas now
Old Mar 22, 2008 | 08:55 AM
Raptor450's Avatar
I would guess 60 - 62 mph.
Old Mar 22, 2008 | 08:28 PM
meathed66's Avatar
I checked mine with a GPS on a dry lake bed. All stock, tires etc. Best I could get with a tail wind was an even 60mph.
Old Mar 22, 2008 | 08:38 PM
race4life254's Avatar
is the 350 faster then a 400ex just wonderin because yall keep comin up with these big numbers.....my dads 400ex does about 65 and it has t-4 pro-curcuit exhuast a jet kit and k&N FILTER and from what i keep hearing yamahas are geared low....and a 350 bored to 360........would run right with a 700....???? huh sumtin dont sound right if you ask me.
Old Mar 22, 2008 | 08:52 PM
my old stocked out 05 blaster ran 52 mph ( beside my dads motorcycle ). i was racing a grizzly 600 and a warrior flat stock. and the grizzly killed us, but the warrior didnt pull away too fast, so im guessing 55mph. but with engine work then the power will rise more then just pipe and jet work. so i still will go with 60-65mph. depending on weight of rider and terrain conditions.
Old Mar 22, 2008 | 09:43 PM
WARRIOR360's Avatar
well would the acceleration be pretty fast if i did
this stuff to my warrior 360
