AWD wedging
Old Mar 23, 2008 | 11:47 PM
duffus's Avatar
Default AWD wedging
My AWD has been wedging a lot lately-- i checked the voltage and the switch works right, but i have to back up to remove it from AWD after it has engaged. I changed the fluid incase there was any contaminants, but it did not help. I can put it in "2x4" and it will still engage the front axle even after i've backed up to unlock it. The voltage is only going to the front axle
Has anyone else had this problem? Fixes?
model: 2005 sp700 carb
Old Mar 24, 2008 | 12:12 AM
Kerbbirds's Avatar
Default AWD wedging
sounds like the cage in the front diff is broken, 200 bucks alone for the cage from polaris, john deere does make the same thing though, someone else on here has the part numbers for it, and there a lot cheaper.
Old Mar 24, 2008 | 12:32 AM
JCDEYO25's Avatar
Default AWD wedging
This might help a little...
http://www.highlifter.com/foru...work/m_1942879/tm.htm
John
Old Mar 24, 2008 | 07:22 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default AWD wedging
the cages from what ive read are very easy to break if someone is spinning and puts in awd. only takes once.
Old Mar 24, 2008 | 05:37 PM
duffus's Avatar
Default AWD wedging
thanks! I don't remember if i engaged it while spinning the wheels... but I could have done this riding around in the snow & ice this past winter.
Thanks again!
Old Mar 24, 2008 | 07:59 PM
onesavage's Avatar
Default AWD wedging
mine "locks in " every time i spin in low while in 2x4..now if i put it high i can spin and no "bang".. go figure?
Jul 24, 2015 11:57 AM
bbertram
Aug 3, 2003 01:10 AM
Buzz440
Mar 12, 2003 03:54 PM
