Changing front and rear gear oil.
My service manual doesnt say how much oil is recommended for the front and final gear boxes. So I figured I would check with the pros on here. Also, any recommendations on oil are also welcomed.
Thanks,
Forrest
Thanks,
Forrest
Fill to the bottom of the threads
You can also get the owners manual from Yamaha online
Link: http://www.yamaha-motor.com/ou...nuals.aspx?ls=outdoor
You can view it and I believe even save a copy!
Mantastic! Thanks Steve. Also, what synthetic would you recommend? I am thinking about getting Castrol Syntec 75W90 or should I just get the original SAE 80 GL-4 Hypoid gear oil?
I run the Valvoline semi-syntheic (I think they call it Dura-blend) 80W90 mostly because it states that it is for Hypoid gears. I have been told that the Mobil 1 and the Castrol Syntec 75W90 is just fine too.. but.. they do not specifically state they are for Hypoid gears. So to save face (warranty wise) I am using the Valvoline 80w90 semi-syn until warranty runs out then I will go with a full synthetic.
