Changing front and rear gear oil.
Old Mar 24, 2008 | 10:29 AM
Forrest1's Avatar
Default Changing front and rear gear oil.
My service manual doesnt say how much oil is recommended for the front and final gear boxes. So I figured I would check with the pros on here. Also, any recommendations on oil are also welcomed.
Thanks,
Forrest
Old Mar 24, 2008 | 10:36 AM
Hondarider27's Avatar
Usually they say to fill to the threads.
Old Mar 24, 2008 | 10:41 AM
Forrest1's Avatar
My fear is that if I over-fill I will blow gaskets and all that good stuff.
Old Mar 24, 2008 | 12:31 PM
CraZySteve's Avatar
Fill to the bottom of the threads
You can also get the owners manual from Yamaha online
Link: http://www.yamaha-motor.com/ou...nuals.aspx?ls=outdoor
You can view it and I believe even save a copy!
Old Mar 24, 2008 | 01:18 PM
Forrest1's Avatar
Mantastic! Thanks Steve. Also, what synthetic would you recommend? I am thinking about getting Castrol Syntec 75W90 or should I just get the original SAE 80 GL-4 Hypoid gear oil?
Old Mar 24, 2008 | 01:32 PM
CraZySteve's Avatar
I run the Valvoline semi-syntheic (I think they call it Dura-blend) 80W90 mostly because it states that it is for Hypoid gears. I have been told that the Mobil 1 and the Castrol Syntec 75W90 is just fine too.. but.. they do not specifically state they are for Hypoid gears. So to save face (warranty wise) I am using the Valvoline 80w90 semi-syn until warranty runs out then I will go with a full synthetic.
bucklove007
Jun 8, 2015 07:28 PM
cornermike
May 27, 2015 10:04 PM
ragewraps
May 27, 2015 08:07 AM
MrElussive
Oct 26, 2000 02:30 PM
