04 Honda 400ex starting problems
Old Mar 24, 2008 | 07:43 PM
Yammer rider's Avatar
Default 04 Honda 400ex starting problems
I have an 04 honda that I recently purchased. It has a good battery that i have tried in my other wheelers but when I press the starter button it wont do anything, Any Ideas?
Old Mar 25, 2008 | 11:23 AM
Dans 07400ex's Avatar
check the fuse
Old Mar 25, 2008 | 12:01 PM
jrafter's Avatar
yea 30amp fuse i think its next to the battery
Old Mar 25, 2008 | 12:28 PM
Patches3489's Avatar
if its not the fuse check the solenoid for a click (it should be close to the battery as well) when you hit the start button. If the solenoid doesn't click it is bad.
Old Mar 25, 2008 | 02:46 PM
hondabuster's Avatar
Do you have a neutral light( when you try to start it)? Have you tried pulling in the clutch lever, while trying to start?
Old Mar 25, 2008 | 04:16 PM
Matt1980's Avatar
change the spark plug
Old Mar 25, 2008 | 04:39 PM
jrafter's Avatar
yea make sure its in neutral
Old Mar 26, 2008 | 12:40 AM
Higgy's Avatar
By does nothing do you mean no noises or movement or it just clicks? Make sure the kill switch is in the middle position, and if it is, then you might want to troubleshoot that circiut. I figure you have the kill in the right position, just covering all the bases!
Old Mar 26, 2008 | 11:13 PM
Thanks a lot guys it was a combination of the fuse and crappy connections.
Land_shark1
Jul 10, 2015 12:53 AM
DTroyer01
Jul 3, 2015 07:34 AM
1000gade
May 27, 2015 12:37 PM
lovinhonda
Jan 25, 2000 09:17 PM
roktoy
Aug 25, 1999 04:37 PM
