4wd 03 scrambler
Old Mar 25, 2008 | 01:24 AM
atvrider007's Avatar
Default 4wd 03 scrambler
i cant seem to get my awd to work wut are the ohm to each hub and was wondering wut to look for if there was a problem if maybe suthin not lined up right thanks
Old Mar 25, 2008 | 06:29 AM
Alpine2's Avatar
First make sure you have voltage to your switch does the light come on when it is switched on? If so start checking the wires to your hubs for breaks they are grey wires.
I think there should be 24 omhs to your hubs not positive on this.
If there is no power to your switch check the grey/white stripe wire that goes to it for voltage. If there is no voltage in that wire you can tap into that one with a red wire from the ignition to see if it works.
hope it helps good luck
Old Mar 25, 2008 | 08:16 PM
the awd switch does work and lite up i have about 30 to 31.5 ohms on each one hub cuz the hubs kida work when they feel like it so there may be power but not enough of strog enough if the ohms are higher ill try to find a spec thanks
Old Apr 5, 2008 | 12:12 AM
MECHANIKE's Avatar
HIYA,THE ARMATURE PLATES ENGAGING THE HILLIARDS ARE VERY DEPENDANT ON TOLERANCE,MEANING THERE CANNOT BE NO PLAY IN THE HUBS,JACK UP THE BIKE+12+6 MOVE THE WHEELS TO CHECK FOR PLAY, YOU NEED TO FEEL NONE.ALSO MAKE SURE FLUID IS UP+ CLEAN.
Old Apr 6, 2008 | 12:04 AM
so turn the wheels and there shouldnt be any play side to side
Old Apr 6, 2008 | 12:17 AM
what parts would be looking to replace if i had a little play in the clutch
Old Apr 6, 2008 | 12:43 AM
MECHANIKE's Avatar
put your hands at 12+6 oclock+try rocking back+forth.if you have play you want to take apart+inspect clutches+bearings,very unforgiving of play.
Old Apr 6, 2008 | 12:53 AM
well im thinking i did have play cuz the hub keept coming loose off the strut part when l i was on the trail last cuz if i squezed the brake it would make the hub and strut closer
Old Apr 6, 2008 | 01:05 AM
MECHANIKE's Avatar
OUTCHEY!!!!!!!!!!! SOUNDS LIKE COMPLETE CATASTROPHIC FAILER!!!!!!!!!!!!!!!
Old Apr 6, 2008 | 01:07 AM
but ill look at it tommorow all the plates and such
