Worst day of riding... ever
Old Mar 25, 2008 | 01:47 AM
FlaKmunKy's Avatar
Default Worst day of riding... ever
K, so I go out digging and the guy who had it before me put the lug nuts on backwards... so they started bouncing out and I damaged my studs. On top of that I lost my key... How much is it to get a new key from the dealer?
Old Mar 25, 2008 | 03:31 AM
JeffinTD's Avatar
I wouldn't think the new key would be too much. Heck, for that matter, new studs shouldn't be too bad either, assuming they are too bad to just run a die over...
Old Mar 25, 2008 | 11:26 AM
FlaKmunKy's Avatar
I am hoping it will be easy for the dealer to get me a new Key and I dont have to take out the cyl thing and bring it to someone to make a key for it.
About the Dye thing... I didnt think of that lol, ill give that a try.
Dont get me wrong people I am not saying honda bikes suck.. I am just saying I had the worst luck ever with the one I just bought... Its got such pep though, a new cam, yosh exhaust.. Bery Nice.
Old Mar 25, 2008 | 02:54 PM
zooooom's Avatar
Try breaking the handlebars after coming off a jump. Then you can say you've had a bad day.
Old Mar 25, 2008 | 07:48 PM
Seemer's Avatar
If you didn't write down the key code from the original key.
(the # can be found on the side of the ignition switch, you have to strip down the console to get it) Up here in Canada it cost me around 75.00 +- For a regular key.
Not the rubber coated one!!!!! from the friendly dealer.
You can buy a new ignition switch off ebay with 2 rubber keys for about 60.00+-
I think the install is pretty straight forward, I'm not sure of any computer stuff that may be required with the new switch.
Old Mar 26, 2008 | 12:49 AM
Higgy's Avatar
Had the same thing happen to me once, but I was the only one at fault! Put lugs on backwards, worked themselves loose, and by the time I realised what was going on the studs were f'd and the holes in the wheel were all egged out! Was about 4 hrs from home, so all it took was a trip to a local hardware store for some nuts, washers etc. Then had to replace all the studs and both wheels when I got home! Will never make that mistake again! As for the key, if you cant get a good deal from the stealer for a new key, I would do as Seemer said and get a replacement ignition off ebay. Should just be a couple of splices, or terminations, and you'll be good to go.
Old Mar 26, 2008 | 03:09 PM
pbugaiski's Avatar
yah my wifes ex 300 is missing the key, it is only a switch so nothing to do with the computer.
I didn't want to shell out the key $ so i switched her hi low beAm light switch to the on off switch ( her high beams are like my low beams) and plugged the hole where the key went with a large round auto trim clip (the large kind in old vans to hold the ceiling up and a nut and washer on the other side ) and a blue diode on the gas tank to let me know the bike is on.
the kid i bought it from musta rolled it something fierce , i'm just finally gettin it perfect after 2 months a tinkerin....it s only a year old!
Old Mar 26, 2008 | 05:24 PM
j9m9t's Avatar
Another option for the key is call a locksmith you might get lucky
Another option is something I did on a Honda 300 is get a on-off-on double terminal switch for about $8 and then you use one set of terminals for the on/off and you use the other side for the kill. Take a big washer and put it in the key hole.
Worked for a year till I exploded the rear end -28" outlaws and a fallen tree is a bad combination on a 2 wheel drive)
Old Mar 27, 2008 | 11:39 AM
FlaKmunKy's Avatar
So I got a key cut with the code of the ignition... it doesnt work, the guy who was cutting it is a *** [img]i/expressions/face-icon-small-sad.gif[/img]
Old Mar 27, 2008 | 06:37 PM
j9m9t's Avatar
hey you might want to try something i have had to do before. Take the key and stick it in the ignition and turn it back and forth a couple of times and then pull it out. you should be able to faintly see were the key is hitting. take a small file and cut away the part that is hitting. You might get lucky, I have about a 50/50 rate of success
