magnetic switch 2004 scrambler
Old Mar 25, 2008 | 01:46 PM
ATKmetz's Avatar
Default magnetic switch 2004 scrambler
bike will not turn over since i replaced switch(mounted to battery box) i measured 12V coming from key switch (small red wire terminated on switch)when key is turned but it will not trigger magnetic switch to send battery amps to starter did i get a faulty new switch? i checked connections several times i have a brand new battery(fully charged) anyone have this problem before am i missing a ground or something the switch i got has a slightly different ending part number but they have the same ratings 12V and i did get it from the dealer here in town. does any one know how to test the magnetic switch with a multi-meter??
Old Mar 25, 2008 | 04:58 PM
ftwflh's Avatar
switch the big cables around.Can you short around the post and get the starter to turn.If not pull the starter and jump it with a batrry charger.
COFatboy
May 2, 2020 12:06 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
velcro7279
Aug 24, 2015 01:15 PM
maxjung
Jul 13, 2015 05:11 PM
