raptor 350 sprocket ?
Old Mar 25, 2008 | 11:06 PM
goodling14's Avatar
Default raptor 350 sprocket ?
to get the top speed faster on a raptor 350.. would you use a bigger rear sprocket and a smaller front.. or a bigger rear and a bigger front..??
Old Mar 27, 2008 | 05:44 PM
slydogsrus's Avatar
1. smaller "rear" sprocket will give you more top end but less low end
2. larger "front" sprocket will give you more top end and less low end
The easiest mod would be to change your front sprocket to a larger one to gain more top end. So if you have a 13 tooth you could install a 14 or 15 tooth to gain more top end, but you will lose low end power.
Best of luck.........
Old Mar 27, 2008 | 06:01 PM
recon99's Avatar
Good luck to get a stock 350 to squeeze much or any more top speed from a taller gear ratio unless you're going downhill. The stock gearing is the best you're going to get for top speed unless you have smaller tires or engine mods.
bmxatv10
Oct 14, 2022 06:23 PM
buddieboy
Dec 9, 2016 05:50 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
