DS650 Rear Shock Question
Old Mar 28, 2008 | 04:32 PM
garman351's Avatar
Default DS650 Rear Shock Question
Hi Everybody:
I have just bought a 2004 Ds650 Baja X model
Being a bigger guy I tightened down the rear spring on the mono shock to make it stiffer. I noticed an adjustment **** on the side oil canister if I turn it clock
wise will it make it also more stiffer?
Will somebody please help me on this?
Also who makes bigger springs if I end-up needing to replace the stock one for a bigger spring to hold a bigger fellow. How much of a pain & cost to upgrade my shock and where can I buy a bigger rear spring?
What can anybody tell me about the rear mono shock thing on these quads.
Thanks
Garman
Old Sep 20, 2008 | 11:30 PM
beerbudget's Avatar
Default DS650 Rear Shock Question"></title><script src=
I see this is a few months old, but can anyone help with these questions? I have the same questions. Any help would be great. Thanks!!!
Old Sep 21, 2008 | 02:05 AM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
http://eibach.com/cgi-bin/star...lient&q=springs+eibach
Old Sep 21, 2008 | 09:42 AM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
you may aslo be able to buy a sring from works shocks or King shocks. you may also consider having the shock revalved. a stiffer spring will make the shock MORE springy and may cause the rebound to over ride the valve. call works & talk to Sandy & see if you stock shock can be revalved & set up for your weight & how you ride. i use Pro G3 shocks from them as i wasted my stock shock running a + 6 swing arm. the proper valving is the key not a bigger spring.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
07Redrider400
Jul 25, 2015 05:31 PM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:40 PM
