Raptor Octane Limits
Old Jan 18, 2001 | 01:19 AM
101raptor's Avatar
I've always had 2 strokes and ran aviation fuel because it was cheaper than Trick Racing.Is it bad for the valves or is it to early to tell?
Old Jan 18, 2001 | 01:38 AM
NakedRaygun's Avatar
Without modifying the compression ratio of the Raptor you do not need to run a high octane fuel.
You won't see a performance gain by just running a higher octane fuel.
Aviation fuel vs. Race gas is another discussion. Basically I wouldn't run aviation fuel.
Old Jan 18, 2001 | 03:04 AM
No2StrokeBs's Avatar
Never run more octane than you need to. Run only what you have to. Maximum power is produced right at the point of detonation. With the low compresion that the Raptor has you could actually get away with 89 octane, but i wouldnt recommend it. Octane levels only resist detonation, nothing more. Higher octane it not "cleaner", nor will it make you engine "perform" any better. So in review, higher octane is not needed unless it is needed. Most 4-strokes do not require anything higher than 93 unless you go over 11:1 compression, and i dont think there is a stock quad that is that high, or no where near that high, most are around 9.2:1
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
