Rear Disc brake hub... can't seem to slide it on the axle
Old Mar 31, 2008 | 11:14 AM
Entomber's Avatar
Default Rear Disc brake hub... can't seem to slide it on the axle
I'm having a hard time sliding it over the axle into it's place. There is an O-Ring in there if I remove slides in.. but once the O-Ring is set in the hub it won't slide over the initial thick part of the axle. I also recall removing it being difficult I had to tap it out with a rubber mallet (and pretty had too). Any trick on getting this on?
Old Mar 31, 2008 | 12:02 PM
McKay5858's Avatar
i just hit it with a mallet, i'm always a little worried that o ring is gonna pop out of its groove but it always stays put. sometimes ya just gotta use a little force i guess
Old Apr 1, 2008 | 02:43 AM
R00ST's Avatar
yup use the force! I couldnt get mine off either, and didnt know about that o-ring inside the brake hub! Just rotate it 5-10* per hit, and keep at it until it pops off!
STLyamwar
Jul 25, 2020 04:44 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
Rider252
Jul 6, 2015 03:37 PM
