2007 raptor chain adjustment
Old Mar 31, 2008 | 03:22 PM
ned_28's Avatar
Default 2007 raptor chain adjustment
i have 2007 raptor 700 se. right now my chain doesn't need to be adjusted. there is a specal rod i need to put in the axle housing to adjust it, or so i'm told , where do i get this tool, thanks
Old Mar 31, 2008 | 03:30 PM
bberck's Avatar
I use a long screwdriver and works just fine.
Old Apr 2, 2008 | 03:37 AM
viper5's Avatar
I use a long allen wrench and stick it thru the sprocket hub after you loosen the 4 allen pinch bolts just pull the quad backwards and it will tighten the chain
Old Apr 2, 2008 | 02:17 PM
ned_28's Avatar
does it have to be a certain size or thickness, thanks
Old Apr 2, 2008 | 02:30 PM
bberck's Avatar
Just has to fit in the hole and be long enough to extend out past the sprocket.
Old Apr 2, 2008 | 03:13 PM
ned_28's Avatar
ok , thanks
Old Apr 2, 2008 | 05:31 PM
ich4bdm's Avatar
or by a drift pin (sometimes refered to as an alignment tool). most hardware stores carry them.
Sjrpp
May 2, 2023 03:59 PM
Firefighter400
Oct 8, 2022 06:38 PM
Sjrpp
Jun 2, 2019 07:25 AM
Zach509
Sport Quads
Aug 3, 2015 02:44 PM
Sjrpp
Jul 5, 2015 09:04 PM
