Magnum 500 rear axle assembly help
Old Apr 1, 2008 | 09:51 PM
djpetrou's Avatar
Default Magnum 500 rear axle assembly help
I have a 1999 Mag 500 and the previous owner did not reassemble the rear axle correctly. I am trying to get the order to assemble the axle, clip, bearings and spacer. He (the idiot) put the clip on before installing the bearing carrier!
So is it Axle, inner bearing, clip, spacer, outer bearing????
Or does the clip go on outboard of the bearing spacer?
The fiche doesn't show it nor does the service manual that I could see.
Any thoughts??
Thanks,
D.J.
Old Apr 1, 2008 | 11:15 PM
sprinter10's Avatar
o wow that is way diff from my scrambler the scrambler just has the bearing pressed into the bearing carier aand then the sprocket then nut then the spacer goes over teh nut to keep it from moving then the snap ring holds the spacer on. let me check my shop manuel for the diagram maby i will scan it and put it up here for you if i get a chance. o i just relized it was a shaft drive right?
Old Apr 1, 2008 | 11:42 PM
sprinter10's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: djpetrou
Any thoughts??
Thanks,
D.J.</end quote></div>
yea thats what it looks like to me in teh manuel in the axle tube inner bearing snap ring bearing spacer then outerbearing axle seal
Old Apr 2, 2008 | 12:23 AM
sprinter10's Avatar
Size:  106.6 KBName:  shaftriderearaxleserviceandbeari-1.jpg
Size:  353.4 KBName:  shaftriderearaxleserviceandbeari-2.jpg
Old Apr 2, 2008 | 10:28 AM
Ujoint's Avatar
You can find the diagram of the parts at:
http://parts.polarisind.com/Browse/Browse.asp
Look under SWING ARM/REAR GEARCASE MOUNTING for the order of bearings/clip/spacer
Old Apr 2, 2008 | 02:54 PM
djpetrou's Avatar
Sprinter
Thanks for the help.
That is one messed up way to retain the axle.
How the heck tdo they expect you to get the outer bearing out while the axle is still part way in and not ruin it. And putting the clip back on wayyyy down in the axle tube is gonna be a blast.
If they'd just engineer the clip to go outside the bearing set it would much simpler!!!!!
Old Apr 2, 2008 | 10:19 PM
sprinter10's Avatar
o and don't forget about the tons of grees and mud in that tube sounds like fun. haha mine was bad enogh in my scrambler and all i have are bearings and seals i put it in teh kitchen sink with dish soap for 2 days still to forever to get ckeen then the bearing didn't come out.
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
bigred20653
Aug 31, 2015 12:41 PM
DeFox500
Aug 14, 2015 05:59 PM
Rider252
Jul 6, 2015 03:37 PM
