Rich or lean?
Old Apr 5, 2008 | 09:38 AM
pinetag's Avatar
Default Rich or lean?
If my Recon pops every time I let off the throttle, does that mean it's running rich?
Old Apr 5, 2008 | 11:12 AM
go-hard-or-go-home's Avatar
check your plug. that will tell you rich or lean. black if rich, white if lean.
Old Apr 5, 2008 | 04:01 PM
hondabuster's Avatar
The pop on throttle letoff is always due to a lean idle circuit.
If youre using blended gas, try using pure gas. If that doesnt cure it, then turn the mixture screw richer (out) about 1/4 turn, and it should go away.
You can verify that its lean...next time before letoff, pull the choke on, and then let off....the pop is gone.
Dammar
Apr 20, 2016 06:03 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
