What is Normal Running Temp on the DS 650?
Old Apr 7, 2008 | 03:47 PM
ERBEDS650's Avatar
Default What is Normal Running Temp on the DS 650?
I put an ESR temp gauge on and she runs between 200 to 210 is this normal or can you get a cooler thermostat?
Old Apr 7, 2008 | 03:49 PM
FDLdsrider01's Avatar
If my DS650 sits at idle for a few minutes it will get up to about 195 but when driving it sit at about 180
Old Apr 7, 2008 | 04:16 PM
ERBEDS650's Avatar
Mmmmmmmm wonder if you can get a cooler thermostat?
Old Apr 7, 2008 | 04:35 PM
DragonDJ11's Avatar
I am not sure what the normal temp is Mitch, but if you are running hot, my guess is you are a little on the lean side....
DragonDJ11's Avatar
And where did you get the guage???
Old Apr 7, 2008 | 04:41 PM
ERBEDS650's Avatar
ESR <a target=_blank class=ftalternatingbarlinklarge href="http://www.eddie-sanders-racing.com/oscmax/product_info.php?products_id=98
">http://www.eddie-sanders-racin...?products_id=98
</a>
Thinking also I swapped out the waterwetter to ICE, I will cheak jetting and get some water wetter and see if there is a differnce.
Old Apr 7, 2008 | 06:02 PM
MRDS650's Avatar
Canadian and Proud of it !!!
Mine runs between 185 - 195 most times. It will hit 200 when in hot weather running hard. I have the same gauge.
Old Apr 7, 2008 | 06:29 PM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
200 is alot on that 730 mrds650 but come to think about it I do run mine as rich on the power jets as I can and turn on the fan when I go ridding after it gets up to 140 so I wont forget about it.
Old Apr 7, 2008 | 06:40 PM
DSengineer's Avatar
Has been here a long time!
With shrouds, engine ice, ODP high flow water pump, NO fan - I normally run 175-180 on my ESR gauge. In really hot weather or putting around with my son it will get up over 200. I find that slow riding brings temps up more than anything on the DS. Running hard it does not get all that hot because it keeps a constant flow of air moving through that big ol radiator...
Old Apr 7, 2008 | 07:45 PM
TheStir's Avatar
Started riding ATVs in 1974!
I have the same gauge, one of the best mods I did.
Mine runs right around 175 to 185 all the time. I was running shrouds but sold them as even duning at 95+ temps the fan only kicked one once in a while when the temp hit 200 while I was going real slow, and then the fan only runs for a few seconds to drop the temp back down.
I run 1/3 Anti Freeze to 2/3 distilled water and Red Line Water Wetter. This gives me freeze protection to 0 and boil over to 265ish due to the 15Lbs radiator cap.
Water has a better thermal transfer than AF, and it also has a lower viscosity. Doing this mix gives me the protection from corrosion, freezing, and overheating I need plus flows better with less strain on the impeller.
