YAMAHA WARRIOR CLUTCH SLIPPING
Old Apr 7, 2008 | 07:58 PM
erikg82376's Avatar
Default YAMAHA WARRIOR CLUTCH SLIPPING
I HAVE A WARRIOR THAT RUNS STRONG UNTILL IT GETS WARM THEN THE CLUTCH STARTS SLIPPING. IT NEVER DOES IT WHEN ITS COLD
Old Apr 7, 2008 | 08:31 PM
recon99's Avatar
What kind of oil do you use?
Old Apr 7, 2008 | 08:37 PM
erikg82376's Avatar
I JUST BOUGHT IT. THE OLD OWNER GAVE IT A OIL CHANGE JUST BEFORE I GOT IT SO I HAVE NOT CHANGED IT YET.
Old Apr 7, 2008 | 11:50 PM
TomM's Avatar
I use Shell Rotella Synthetic 10W50 in mine and have no clutch trouble. All the cluthces Ive wore out in any quad did the opposite they slipped worse when they were cold.
Old Apr 8, 2008 | 12:08 AM
recon99's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: erikg82376
I JUST BOUGHT IT. THE OLD OWNER GAVE IT A OIL CHANGE JUST BEFORE I GOT IT SO I HAVE NOT CHANGED IT YET.</end quote></div>
My first guess would be that they went to walmart and grabbed the cheapest automotive oil off the shelf for the oil change. A lot of people learn the hard way that regular automotive oils have friction modifiers and other additives in them that reduce the clutch's friction and permenantly make it slip.
You're probably going to need to replace the clutch, and to play it safe run motorcycle or atv specific oil that is designed to work with wet clutches. It's a buck or 2 more a quart, but it's cheap insurance that you won't need to be replacing your clutch for the same reason anytime soon.
Ashley S
Jul 31, 2015 09:46 AM
Reactant
Jul 27, 2015 07:45 PM
Reactant
Jul 16, 2015 10:29 PM
ghost civic
Jul 15, 2015 10:48 PM
